Sorry if this is the wrong section. Trying fix a issue on a friends PC because every time he boots up and messes around or let's it sit idle(power saver and sleep is disabled) for about 20 minutes or so it will sometimes will freeze and the screen will go black or if he opens a game or try to install stuff (I tried to install origin update and it went black couple seconds after it started) it'll freeze and go black. So to me this sounds like a GPU failure or a motherboard failure. I did a memory diagnostic and did memtest86 usb and both came up clean. Used HWmonitor and HWinfo. If anyone can recommend another test I can run it'd be much appreciated.
HWmonitor:
2nd HWmonitor:
HWiNFO32 Report(HTML file but it wont display it as a html file so you have to download it):
http://www.mediafire.com/file/wcoghpps188za4s/DESKTOP-1EEEOQM.HTML
This is a Temp Log from HWinfo(its a excel file):
http://www.mediafire.com/file/i5lofdd4quchu1m/temp+log.CSV
Specs of his PC:
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core 2 Extreme QX6850 @ 3.00GHz 58 °C
Kentsfield 65nm Technology
RAM
4.00GB Dual-Channel DDR2 @ 333MHz (5-5-5-15)
Motherboard
Dell Inc 0PP150 (Socket 775) 68 °C
Graphics
DELL ST2010 (1600x900@60Hz)
2047MB NVIDIA GeForce GTX 550 Ti (EVGA) 44 °C
Storage
931GB Western Digital WDC WD10 EZEX-00BN5A0 SCSI Disk Device (SATA) 28 °C
Optical Drives
HL-DT-ST DVD+-RW GSA-H73N SCSI CdRom Device
PBDS CDRWDVD DH-48C2S SCSI CdRom Device
Audio
High Definition Audio Device
HWmonitor:
2nd HWmonitor:
Specs of his PC:
Operating System
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
