- Jul 7, 2006
- 915
- 0
- 0
there are many items there (I have no clue which ones are from the problem periods)Originally posted by: Navid
You get all those errors every time it freezes at shut down?
I was hoping for a more identifiable error!
I am afraid I cannot help.
Hopefully, someone else can figure out which program is causing these errors.
Or, you can re-install Windows.
The User Profile Hive Cleanup service failed to start due to the following error:
The system cannot find the file specified.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
The server {9B1F122C-2982-4E91-AA8B-E071D54F2A4D} did not register with DCOM within the required timeout.
TCP/IP has reached the security limit imposed on the number of concurrent TCP connect attempts.
The Application Management service terminated with the following error:
The specified module could not be found.
that description on the site pretty much gave it away (closest result to my problems as I've been able to find)Originally posted by: MrChad
Is your Windows Update hosed? There's a description of this event error and a fix here.
I tried it and is restarted fine, now when I go to shut down (I'm not talking about actualy shutting down, just clicking Start>Turn off) it doesn't freeze up
So far, so good... if it is successful like this for a few days it's probobly working for good. If not I'll be back
Thank you very much guys for your efforts and helping me figure this out!
Have a nice day![]()
