kd5
Specs (self-built):
ASUS P5P800-VM
Intel 3.4ghz Prescott (LGA775)
630W Corsair PSU
4gb G.Skill PC3200 Cas 2.5
160gb WD SE
Windows 7 HP 64-bit
I realize this is an older computer but I don't have the $$$ for a new one so this is what I'm stuck with...🙁
Until 2 days ago this computer was performing admirably for what's in it. Shut down at the end of the day, no problems whatsoever, woke up the next morning, tried to power it up, no video. Further investigation revealed no power light on the front of the computer. Fans spin up so there's power to at least part of the components. Tested the power supply, it tests fine, green lights all. No apparent swollen capacitors on the motherboard.
Power to some of the components but not enough to start this computer up normally, and no power indicator light on the front of the computer.
Anything I can try? I don't think booting with minimal components will help not getting the power indicator light suggests there's bigger problems. I suspect the motherboard has bit the dust.....dammit.😡
ASUS P5P800-VM
630W Corsair PSU
160gb WD SE
Windows 7 HP 64-bit
