- Mar 9, 2003
- 677
- 0
- 71
My mobo fried I need to get up and running as fast as possible!!!!!!!!!!! Help Please!!
I have been out of the computer hardware loop since I build my last P4 computer years ago. As was expected things have dramatically changed. I am clueless about the new technologies in processors. My old P4P800 board failed and I cannot find a replacement so its time to look for new stuff. I wanted to use some of the old hardware listed in my signature but it appears its pretty much useless in the new technology.
1. What YOUR PC will be used for?
Typical office stuff, DVD burning and occasional editing, surfing and downloading. Be nice to have future video editing capability.
2. What YOUR budget is:
I was hoping to stay under say $500 but would go higher to avoid obsolescence. I really don't know what decent stuff costs.
3. What country YOU will be buying YOUR parts from?
USA.
4. IF YOU have a brand preference?
Intel, Asus, are the only brands I have owned. Gigabyte seems recommended as well.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are?
HP2207H 22" monitor at 1680X1050. For now would like to reuse the 2 120 gig hard drives from my old computer until I get the data off them. Would reuse my Antec Case and 430W PSU if its big enuff which I doubt. Would reuse my optical drives for now. Would upgrade drives later.
6. IF YOU have searched and/or read similar threads?
While I have searched many threads I really don't know enough about the present CPU or mobo technology to make an informed choice. I have to rely on your expertise.
7. IF YOU plan on overclocking or run the system at default speeds?
some overclocking perhaps...nothing drastic.
8. WHEN do you plan to build it?
Immediately
I don't want to drop a ton on a video card at present so a decent budget card would serve me well.
I don't need a top of the line processor just something that will not become obsolete in a year or limit my activities.
The mobo I want something solid and easy to set up. I do not need raid. I do not presently use firewire. Sata is probably a good thing to have if I upgrade.Onboard Lan is a must.
I currently have win XP Pro 32bit. Would I need to upgrade to vista or could I keep it with the new processors. Should I go with a 32 or 64 bit processor..
I am basicaly starting from square one again PLEASE HELP ME out here so I can get back up and running quickly!!! I am down for the count here.
Got this from another thread...for a starting point:
E8400 - http://www.newegg.com/Product/...x?Item=N82E16819115037 - $165
Asus P5Q Pro - http://www.newegg.com/Product/...x?Item=N82E16813131299 - $130
4GB DDR1000 RAM - http://www.newegg.com/Product/...x?Item=N82E16820231145 - $50
GTX280 - http://www.newegg.com/Product/...x?Item=N82E16814130365 - $325
WD 750GB - http://www.newegg.com/Product/...x?Item=N82E16822136283 - $90
Corsair 650W - http://www.newegg.com/Product/...x?Item=N82E16817139005 - $100
Samsung DVD Burner http://www.newegg.com/Product/...x?Item=N82E16827151171 -$26
USA.
Immediately
