Alright, my computer randomly shut down the other day.
On trying to restart I get the recovering from a severe error shtick and choose start as normal, nothing. Try to choose safe mode with networking, nothing (It trys but never completes) all the way down the line. It won't even boot as safe with command prompt.
I tried use last working settings, no luck.
Gave up for a while and came back to it later, making sure nothing was loose etc. I was bending down to look inside as I booted up and my forehead came in contect with the shiny metal parts of my case, which is an antec p160. I felt a mild, constant, shock. This only occurs after I select my boot option.
The most recent time it occured I got an error which looks similar to the following:
Stop C******
registry cannot load C:/*/*/*/*/system (I think)
beginning dump of physical memory
I wasn't able to copy down the whole thing before it rebooted. This was on a blue background. Asterisks represent unknowns.
I tried booting three times after this and did not receive a shock. It would go up to the boot selection menu but then fail to continue.
Any help would be apperciated.
Edit: Forgot specs.
My setup:
Abit IS7 (northbridge fan is dead)
pentium 4 2.4c oc'd to 3ghz
1gig of 3200 ddr (256 x4)
9800 pro 128 meg version
Stop C******
Edit: Forgot specs.
My setup:
