- Mar 11, 2001
- 19
- 0
- 0
I was playing Klingon Academy last night, about to take on a Warbird and the game froze... I was like, ...
So I tried restarting. It wouldnt restart. I shut it down, then turned it back on and all that would work was the fans and the power light, that was it. I could eject the DVD-ROM, but nothing else seemed to work... I couldnt heard the Hard Drives boot up either.
I have the MSI K7T Pro Motherboard with the 4 indicator lights and they were all red... although twice when I tried starting it up the 2 one was green which indicated a keyboard initialazion... but all the other tries they were all red.
According to MSI that means it was either a CPU failure, or a Battery Discharge.
I THINK it's the CPU... but I dunno, I sure hope it's just that or the battery, nothing more serious like the MOBO.
I did unplug all the HD's and Cdroms to see if something was causing a problem and that wasn't. However, I didnt unplug the ram or the video cards and such... I think the mobo would have complained with those lights if one of those things were wrong and it didnt.
Everything in the system is less than a year old -
Specs -
Thunderbird 750 CPU
MSI K7T PRO MOBO
256 Megs Micron SDRAM
Full Tower 300Watt Antec PS
Adequate cooling... (All fans were running including PS fan)
Bios settings were optimal, a little overclocking on the FSB but only 7Mhz
Maxtor HD's
Panasonic DVD 12x
Generic FD
Geforce GTS
SBLive
NIC Card
All the extras such as the monitor and keyboard (Which worked... the monitor anyway)
Yes, I can test these things on other systems but that would be a royal pain because the CPU Heatsink (FOP32) was a pain to get on, that maybe was the problem. It caused pressure that eventually built up (After a year) on the cpu and finally cracked the CPU or something...) taking it off and on and off would probably crack the core for sure .
I just want to know what is the probable cause so I can get the part replaced. If there is anything else that I missed, let me know plz. Thnx!
Specs -
Thunderbird 750 CPU
MSI K7T PRO MOBO
Maxtor HD's
Panasonic DVD 12x
Generic FD
Geforce GTS
SBLive
NIC Card
