- Oct 24, 2007
- 333
- 0
- 0
right, so anyway, my parents have a crap old p4 3.0ghz and a mobo so old it only runs like ddr 5400 (or the ram in that range), so i was putting in my extra 2180 duo and a g31t-m mobo i picked up cheap just to improve their computer. nothing fancy here, 1gig ram, a gforce 7200gs, just basic stuff. Anyway, i put it all in turn the computer on and it goes through the initial bios but when it gets to the windows screen (right after bios when it has the bar on the bottom showing it loading) the screen would be really really dim and i'd get a blue screen for less than a second and then it'd loop back to bios and start over again.
anyway, I tried taking out the gpu thinking maybe it had too much load for the little 350 antec psu they have (it's got to be at least 5 years old btw) and still no dice, same thing happened, bios, windows loading, bsod, then back again. Now I had thought perhaps I had a wire crossed somewhere, but I couldn't see anything abnormal and the bios load was fine, then I heard a pop, and the PSU blew smoke out the fan...now nothing obviously.
Is it just the PSU being old and underpowered or do I have a different problem here (like a short to ground or something of that nature) Obviously I need a new PSU now but I don't want to go blowing out the replacement over something stupid either. The other computer I was building beside it came out 100% so it's not a static thing or a short like that or i'd be noticable on the other computer IMHO.
Any help is appreciated, and thanks guys.
John
John
