Ok,
Heres the deal.
System Specs
Abit KT7A motherboard 1.2ghz processor
512 MB PC 133 Ram
GeForce 4 TI4600 Vid Card
SB Live! Value
3COM 3c509B nic
AGI Amd approved 350 W power supply
Took out all my CD rom drives and HD. So currently only got 1 WD 7200 rpm 40 gig hard drive installed. No floppy, no cd rom.
Heres whats happening. Computer boots up only when it wants to. Which originally lead me to beleive bad power supply. No biggie I thought. Pull out a spare 300 w AGI Amd approved power supply install that, still getting the same issue. So ok, fiddle around with the electrical outlets a bit at my Apt, boots up again, eventually. Screw around on the pc for a while play some Jedi Knight 2. Shut down, go to work come home doesnt boot up again. Ok, whats the deal I thought? Bad power switch I thought. Take everything out, put it in a diffrent sprae case I had lying around. Boots up fine after that. Sweet, everything working ok. So I mess around for a bit. Shut down again. Go to power back up later. Tried another power cable I have on another pc, dont help, still does not boot up.Wont power back up. Power switch does nothing. No random reboots. No random shut downs. So didnt sound like a bad MB to me. I havent checked the CPU temp in a while, but last I did check, it was where it was suppose to be. I jsut moved, and this room gets alot hotter than my last one, havnt checked the cpu temp since I moved out here. Dont remeber the numbers off hand. Could that be the problem if i have a cooling issue?
I have been doing pc support for a while, and never encountered this one.
Any ideas suggestions?
Heres the deal.
System Specs
512 MB PC 133 Ram
SB Live! Value
3COM 3c509B nic
