COMPUSA Viewsonic Projector- $499.00/AR of 200
Chunkee
10,391
ONLINE ONLY, dont know if this is a good deal or not.
JC
ViewSonic Cine1000 Projector, SXGA, 1000 Lumens, DLP
Platform: Mac
PC
Projector Technology: DLP
Native Resolution: SXGA
Video Standards: HDTV
NTSC 4.43
PAL
SECAM
HDTV Ready or Compatible: Yes
Physical Aspect Ratio: 16:9 (Widescreen)
Lumens: 1000
Contrast Ratio: 2000 :1
Light Source Life: 3000 Hours
Light Source Power: 200 W
Port Connectors:
* 1 x RGB Input DB-15
* 1 x RGB Output DB-15
* 1 x DVI Input DVI-I HDCP compliant
* 1 x Video Input RCA jack
* 3 x Component Video Input RCA jack
* 1 x S-Video Input Mini-DIN 4-pin
* 2 x Audio Input Mini-Jack (x1); RCA (x1)
* 1 x Audio Output Mini-Jack
* 1 x Control RS-232 (mini-din, 3-pin
User Controls:
* Main menu (brightness, contrast, sharpness, color temperature, color saturation, color, tint, gamma, color space, reset), setup menu (H. position, V. position, keystone
* Aspect ratio, advance feature, reset), advanced feature menu (user color, white peaking, logo display, reset), configuration, utility, language, status (lamp mode, lamp hour reset)
In the Box:
* Projector
* composite audio/video cable
* S-video cable
* RGB/DVI cable
* power cable
* remote control with batteries
* Quick Start Guide
* ViewSonic Wizard CD (with user guide)
* soft case
Regulatory Compliances:
* UL/C-UL, FCC-B, TUV, CB, CCC
Height: 9.4 in
Width: 12.9 in
Depth: 3.5 in
Weight: 7.8 lbs
Limited Warranty: 3 Years (36 Months)
Warranty Information:
* 3-year warranty on parts and labor
* First-year Express Exchange Service
* 90-day warranty on lamp.
dew042
2,934
They threw me off with the SXGA (1280x1024), which it is not.
Its 854x480. Not bad overall.
dew.
MustangSVT
11,554
12
i will stick with in72 for now ;) but no vga or dvi input sux. but it does m1 dvi look alike input.
