Yes, thermal tape will work fine. I used some that I had to attach an external probe to my T-Bird.
EDIT: Here is a Picture of mine. It could be better by trimming the plastic on the tip of the probe some, but with my Alpha 6035, this was the best I could get so the Alpha would still fit flush on the T-Bird. The tip of the plastic touches the core, and still gives a pretty good reading when compared to the thermocouple results that I looked at in Mike's link on the subject.
does cutting it have any potential negative effects? i mean, wont that allow the thermosistor (the actual wire) to come into contact with the air? is that bad? thx
Just install it like I have mine. Like I said, it is accurate enough that way. I have been thinking about drilling a hole in my Alpha so I could insert the probe directly through it to the core, but until then I am satisfied with the results the way it is setup now.
The less there is between the probe and what you wanna measure temp the better ( unless it is thermal tape, or kinda lie, then you can use to stick it around with small temp misreading.
