Originally posted by: MrToilet
I think both of them are DLP projectors...
And the receiver I'm using is "Dolby Digital ready"- I bought it right when Dolby Digital was released. The DVD player I have right now has a built-in Digital decoder, so it outputs all 5.1 channels to the receiver via RCA inputs.
So how would I hook up an Audigy 2 ZS to a receiver like this? I suppose I would have to get a whole new receiver and everything...
AE700 is an LCD projector
so is the Z3
Not that there's anything wrong with that.
Ok, so your receiver has 5.1 analog in that you're using from your DVD player. If you intend to get surround sound from your computer, then using that 5.1 analog input would be the easiest way to do that.
If you plan to use both a real DVD player and a computer as an input and want true surround sound from both, it seems like you're going to need a new receiver.... or you could make yourself a manual switch to select between which set of 5.1 analog inputs your receiver is using as the source.
Depending on your budget, it might be a good idea to invest in a more modern receiver. You can then hook up your DVD player via digital and get surround sound since your receiver will be able to decode the AC3 stream your DVD player will output and you can hook up your computer too.
If stereo sound is ok for you for all your computer material, then you could just hook up your computer via analog 2 channel on a standard input and then either keep it stereo on your receiver or select prologic or whatever it has to play from all speakers.
If you want surround sound in movies and stereo for games/music from your computer, then you could hook up via a digital connection on a new receiver.
If you want sourround sound in movies and games from your computer, then
1. you'd need to hook up via analog to a 5.1 input like your DVD player is hooked up now on a your current receiver and use the computer's DVD drive to play movies
or
2. get a new receiver with 5.1 analog input and use that for your computer while a real DVD player is hooked up via digital
or
3. get a new receiver that doesn't have to have a 5.1 analog input and use a soundcard that does Dolby Digital Live and hook up both the computer and DVD player via digital to the receiver.
Sorry if this post is totally random in its organization, I stopped halfway through and ordered some b-stock Onix Rocket 550 risers that I was informed were in stock... woot!
