Component vs HDMI from HD Cable Box
jdoggg12
2,685
11
I noticed after hooking up both HDMI and Component outputs on my Scientific Atlanta 8300HD DVR that on non-digital channels the signal from HDMI is pretty crappy. The only channels that look good are the ones in HD, everything else is subpar.
Is anyone else experiencing the same/similar issues?
My provider is Cox if it matters.
Muadib
18,124
912
Are you saying that the standard channels look worst on HDMI than they do over component?
jdoggg12
2,685
11
Yes. So my HBO non-HD channels look better using component. There's little difference in the HD channels though
Sep 12, 2004
16,852
59
86
I wonder if it's trying to do some crappy upconversion of the SD channels via HDMI whereas the same thing doesn't happen via component?
Have you tried playing with the video output settings of the cable box to see if that makes any difference?
Captante
30,353
10,876
I did notice that colors seemed slightly more saturated using component, however once I calibrated my TV that problem went completely away ... I've gone back & forth a couple times since calibration & at this point I honestly can't tell any difference at all between the two.
PurdueRy
13,837
4
When I compared my Toshiba HD-A3(HDMI) to a Panasonic DVR/DVD player the HDMI initially looked much better when displayed on a Samsung HP-S5053. However, once I went into the panasonic's settings and changed black level to "darker", the sets were very similar in appearance provided a DVD was playing in both.
Rio Rebel
Administrator Emeritus<br>Elite Member
This is not that surprising. It's not because the cables make such a difference, but because you're not comparing apples to apples out of your display. Displays can look very different from one input to the other. My projector looks very close out of the box through the DVI connection, but I had to really work with calibrating the component input to get it close.
Muadib
18,124
912
I agree with you. Odds are the OP didn't calibrate both inputs. TastesLikeChicken could also be right. The OP's box has 2 upconversion settings. Try the pass through setting and see what you think.
jdoggg12
2,685
11
I'll try that - thx
