theAnimal Diamond Member Mar 18, 2003 3,828 23 76 Nov 16, 2008 #1 I'm using a component connection from DVD to SDTV. The picture quality is very good, but would using component cables improve it?
E erwos Diamond Member Apr 7, 2005 4,778 0 76 Nov 16, 2008 #2 Possibly. Not all cables are created equal, especially on the analog side of things.
S Slick5150 Diamond Member Nov 10, 2001 8,760 3 81 Nov 16, 2008 #3 Originally posted by: theAnimal I'm using a component connection from DVD to SDTV. The picture quality is very good, but would using component cables improve it? Click to expand... You mean you're just using cables intended for composite + stereo audio (yellow, white, red) and plugging that into the 3 component video outs? Its possible that getting cables intended for component would help a little, but I doubt you'd notice that big of a difference.
T Tiamat Lifer Nov 25, 2003 14,068 5 71 Nov 16, 2008 #4 Here is a thread that may help you decide. Link Basically, it depends (is the answer). If they are all 75-ohm cables, you should be fine, but there is no guarantee that they are.
SonicIce Diamond Member Apr 12, 2004 4,771 0 76 Nov 16, 2008 #6 If it's for a short run (less than 10 feet), it probably won't make a differance what you use unless they're really crappy.
