Hey guys,
So my UE TripleFi 10's have arrived (will only get them for my b-day though
Now, I've looked to check that everything has arrived correctly, and I did think you were supposed to get one set of comply's as standard, however I got two (grey ones of course though).
Now when I need to change them later on, should I look to get the T-500s or the TX-500s?
I know the difference is the ear-wax guard/filter, but I've heard that sound production and throughput can be hampered by the filter. Can it?
I'm mainly confused as the Comply website calls the T-500s "Personal Audio" and the TX-500s "Audiophile". I really don't understand - I'm guessing it's just marketing as the TXs are more expensive.
Hope you guys can give me some guidance on this.
