Geez, the choices here are abundant, I'm like completely overwhelmed. In any case, it's either going to be an A64 3500+ or an A64 X2 3800+, and I'd be hoping to overclock either of them at least a bit, I never go hog wild overclocking anyway. It will be on the Asrock 939DUAL-SATA2 as well.
I was considering either the Scythe SCNJ-1000P or the Arctic Cooling Freezer 64 Pro. The 64 Pro seems to have the leg up simply in installation, but depending on the review you read the 64 Pro ranges from nearly silent to a turbine engine. I'm guessing either one would be ok for my relatively modest overclocking ambitions, but the Scythe would require the purchase of some AS5 (I'd just use the MX-1 included with the 64 Pro if I got that).
I did notice the Scythe doesn't seem to actually do the whole "airflow over the mobo power regulators" deal since the bottom fins don't seem to be angles in any way.
In any case, would either one be alright for my needs, if so I would probably just go with the 64 Pro, but seeing as how the scythe isn't that much more money I'd be willing to spring for it and the extra for some AS5 (unless I decide to reuse some old Ceramique I have sitting around).
Price has basically eliminated the Zalman from the running though.
