compilig using borland or djgpp
asad
56
hi to all
how could i compile more than one file using borland or
djgpp compiler for c++.
thanks in advance
asad
56
thanks for replay
when i download a source code for a program i got many files some files have the .cpp and some other have .h extension
and other extension .dsp .dsw .vbp all these file extension in the same package of the program source is the compiler need the file.h ?
in this case is the command line will be change?
what about the files extension i mentioned above?
thanks
Nothinman
30,672
dsp and dsw are Visual Studio workspace files and VBP would be a Visual Basic project file, none of those are relevant to djgpp or borland.
.h files are header files and are included by the c/cpp files that need them.
asad
56
so is the command line will change?
do i put the .h files to the library?
Nothinman
30,672
No, .h files are #include'd from the .c/.cpp files so you don't have to do anything with them.
