Compatibility Check
IndyColtsFan
33,655
687
With a nVidia GF 8800GTS, that same setup would've been happy with a 300W or 350W PSU.
I think the calculcation came out to closer to 350 W or 400 W IIRC. Nevertheless, I didn't buy the power supply solely based on wattage; it was cheap and had the connectors I needed. It has been running 24/7 for nearly 4 years now and I'm pretty impressed despite the mixed reviews the OCZ units sometimes get. I ended up buying two more and haven't had one die yet (knock on wood!).
If the OP were getting a decent 750 W power supply for only a $20 premium, I'd probably say "go for it," but in this case, it is a $70 premium and that could be used to upgrade his graphic card.
dclive
5,626
Calculations are typically made by PSU manufacturers, and err on the side of making the manufacturers more money. Kill-a-Watt said something like 300W or 320W, something like that - measured at the wall. Since the PSU is inherently about 20%-ish inefficient, that means the computer parts/etc. are actually drawing (using) only 80% of that, or perhaps 260-ish watts.
I could be off by 20 watts or so, but the point is - I'd not trust the "calculations" sites as anything more than a very high estimate. If you want real information, buy a Kill-A-Watt meter for $20ish.
dclive
5,626
>LEGACY: Amiga 2000 | GVP 68030 w/ 8 MB RAM | A2091 w/ 52 MB hard drive | Dual floppy drives<
What do you do with this these days?
IndyColtsFan
33,655
687
Nothing serious -- I just play around with it, play the occasional game, and mess around in Deluxe Paint III or Photon Paint. I also enjoy upgrading it with cheap hardware from eBay. When it was my main system, I was in college and couldn't afford to upgrade it. I've upgraded it with a 68030 accelerator and a flickerfixer and have it attached to an LCD monitor. For transferring files between the Amiga and a PC/internet, network cards are ridiculously expensive for the Amiga so you generally either have to use floppies, a serial cable network, or a Zip drive. I had a 250 MB USB Zip drive for the PC that I got free, so I eBayed a 100 MB SCSI one for the Amiga and it works perfectly. The irony, of course, is that a single Zip disk is twice the size of the hard drive. :D
I'm a Commodore fan and also have my C128 on my desk, cabled with a custom cable I built to my 42" 1080P plasma in my man cave. :D I hope to eventually acquire an Amiga 1000 as well. Retrocomputing is a blast and it brings back a lot of great memories.
IndyColtsFan
33,655
687
Calculations are typically made by PSU manufacturers, and err on the side of making the manufacturers more money. Kill-a-Watt said something like 300W or 320W, something like that - measured at the wall. Since the PSU is inherently about 20&#37;-ish inefficient, that means the computer parts/etc. are actually drawing (using) only 80% of that, or perhaps 260-ish watts.
Buying a Kill-A-Watt would do me no good while I am still building the system and have no parts. I have to go off estimates -- hand grenade accuracy is fine for me, I don't need smart bomb accuracy. :D When I bought this 600 W supply, it was about the same price as a 400 W one so why not?
