Compatability check for all the parts of my computer
HaelWho
I'm fairly certain, but just to make sure:
ABIT AN8-ULTRA Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16813127212
Thermaltake Tsunami VA3000BWA Black Aluminum ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16811133132
AMD Athlon 64 3700+ San Diego 1GHz FSB Socket 939 Processor Model ADA3700BNBOX - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16819103539
BFG Tech BFGR78256GTXOC Geforce 7800GTX 256MB GDDR3 PCI Express x16 Video Card - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16814143036
Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16822148065
OCZ Gold Series 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZ4001024ELDCGE-K - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16820227211
SAMSUNG 913V-Black 19" 12ms LCD Monitor - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16824001192
THERMALTAKE Silent Purepower W0010 ATX 480W Power Supply - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16817153009
NEC Black IDE DVD Burner Model ND-3540A - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16827152047
LITE-ON Black IDE DVD-ROM Drive Model SOHD-16P9SBLK - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16827131410
SONY Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16821103116
Thanks, excited to be building this 😀
Looks good except the PS. Probably OK if your not going to OC, but 18a on the 12v is weak, and TT isn't known for great PS's.
Everything looks great except for the DVD burner & perhaps the PSU.
I had that PSU & had zero issues, but others here seems to feel it's no good.
An Enermax Noisetaker or OCZ Powerstream might be better choices.
As for the DVD burner, the BenQ DW1640 would be the one i'd recommend 🙂
Well, I like the DVD burner, and from personal experiences with a BenQ monitor, I don't know if I trust them completely to be honest.
As for the PSU, the Enermax and OCZ both barely exceed my budget, so how's this look:
http://www.newegg.com/Product/Product.asp?Item=N82E16817182009
Thanks for the suggestions guys.
No Rosewill not so good.
Text
I dont have any experience with Rosewill, nor do i know what quality they have, but as far as power and amps go, thats a good PSU (26A on the 12volt)
Same thinking as me. Only experience I've ever had with Rosewill was installing a friend's Rosewill video card.
well, just to help you out, look for PSU's made by Fortron, PC&C, or OCZ and you will not be disappointed at all
whats your limit for price on the PSU?
You never wanna go cheap on the PSU 🙂, this is what I got
Fortron Blue Storm
An OCZ powerstream is good too.
downgrade your CPU to a 3500 and get 2 gigs of RAM. no offense, but that rig seems neutered with only 1 gig of RAM
Don't have any personal experience, but have seen several others that had good luck with that PS
