Comparision between (T6200 & DA5000pro) and between 2 sound cards
el-mariachy
Dear members ;
first of all , I new here and i would like to apologize if I'm posting in the wrong thread/forum
second:
I have 3 questions and would like you to answer them for me ,
first question :
I have Creative sound system T6200 ( here)
and I'm willing to buy Edifier DA5000 PRO (here)
the question is : will it worth to upgrade from Creative to Edifier ?
Second Question :
I have Creative sound card > Sound Blaster X-Fi Xtreme Gamer (here)
and I'm willing to buy : Creative Soundblaster X-Fi Surround 5.1 Pro USB Audio System with THX SB1095 ( here )
the question is: will it worth to upgrade from Xtreme gamer to Sound blaster Pro ?
- is the Creative Soundblaster X-Fi Surround 5.1 Pro USB Audio System with THX SB1095 is the best " EXTERNAL" Sound Card around 60$
Last question : If I bought the Edifier DA5000pro and connected to the " external" sound card ,will it work smoothly or there would be a Conflict ?
** is there any thing I should know before buying the " External" sound card and the Edifier Sound System ?
thanks for your time and for your help
el-mariachy
someone advised me on buying the Asus DX with my new sound system the Edifier DA5000 PRO , and told me that it is better than the External USB creative sound card !
what is your suggestions ?
kornphlake
1,567
9
The Asus sound cards are consistantly recommended over creative labs cards for sound quality. I have no personal experience with the specific products you recommend, but research suggests that whomever recommended the Asus is most likely correct.
