Comparing SN41G2 and SN45G. Questions...
codeyf
11,854
Is the only thing the fact that the 45 supports (officiall at least) the 400mhz bus? Pricing them out, the 45 is roughly $15 cheaper. There any other differences I'm missing? I'm looking at tossing in a 2500+ Barton in one of these. Cost is definitely an issue. The less, the better. Would definitely like the nForce2 chipset tho.
drquest
1,148
7
G1 case instead of the G2 case and integrated graphics which is one reason the SN41G2 doesn't do 400mhz.
I have an SN41G2 and it's a nice machine.....
mrpeabody
codeyf
11,854
Ok, so I prefer the G2 case, but the G1 is fine. I'm using a Ti4800SE anyway. Will be using just a single stick of PC2700 for now, till I get some $$ for an upgrade there. Then will prolly go dual-channel PC3200 depending what prices are in a few months.
So, those are the only differences, right? I might as well save the $15 and get the 45G.
