imported_kushko
The last PC I had was an ASUS A7N266VM with a Duron 1.2 GHz CPU and an ATI 8500 GPU. At the time it was a pretty good setup for a "budget" system.
I was going to build a new system to replace this one when I saw a Compaq SR1710NX (Specs, Motherboard). I also needed to upgrade my OS from WinME, so I needed to figure that cost into the equation too. The Compaq with OS+ ended up costing me $430CDN, a lot less than even putting together a very budget system.
The Compaq has:
939 Motherboard with ATIs RS480, dual channel capable, x200 integrated graphics
Sempron 3400+ (not dual channel capable)
PCI-e slot
100GB SATA
Win XP
I know you'll say the graphics suck for gaming, but because most of the games we play in our house are 2 years old anyway I figure the x200 will do for now.
The things I like about this setup is:
1) The MB allows me to use an Athlon 64 or X2 when I have some extra money
2) The MB is dual channel capable, so I can add another 512MB DDR to the one I have (when I replace the CPU) and get even more performance
3) I can replace the integrated graphics with a PCI-e card.
I'd like to know what others think of this PC.
Thanks,
Kevin
The Compaq has:
PCI-e slot
100GB SATA
Win XP
Thanks,
Kevin
