- Jul 24, 2000
- 979
- 0
- 76
Just recently picked up a laptop, and it seems to "work", to some extent. Actually, the only thing that works are the ac plug light (on mobo), power light (on LCD), and battery light (on LCD).
When the power button is pressed, only those lights would turn on (of course, that means the laptop is using the ac plug w/ the battery plugged in
). The hd, fan, and lcd screen don't work. They just sit still and do nothing. What's the most common part(s) in the laptop's or desktop mobo that fail?
I'm not sure, but the laptop has a button (or a pushable pin) near the LCD hinge. When the LCD screen closes, the pin is pressed down. Can a defect in the pin cause such problem since it's either constantly closed or opened?
BTW, the laptop is compaq presario (series 700 and model 715us). I believe every other components work, just not the mobo. Many presarios seem to have this problem, so I'm just wondering if anyone has a "fix" for it.
