Compaq Laptop fade to white problem???
Padriac
1,088
I recently picked up a used Compaq 1592DMT from my dads office. Here's the specs if it matters, I suppose not but, 233, 3.2gig, 32megs, 12.1TFT, Li-Ion. Anyways, in both win95 and win98 every once and a while the screen just goes zoink and fades to white, I know everything is working behind because I can still do stuff, like change music tracks and such, however the screen is just this hazy white. If I go into stanby and then come back its fine, or if I shut down and turn the computer it is fine, sometimes it happens agian but if you reset a couple of times it works fine. Doesn anyone have any ideas, hopefully this isn't a huge problem? Somebody...
Padriac
1,088
Somebody must have some idea what this is, break it to me gently would you?
Workin'
5,309
Make sure your display settings are correct (proper video card criver and monitor type selected) and set the vertical refresh rate to 60Hz.
Had a problem that seems the same with one of my lappys and it turns out the video settings were slightly outside spec. It would work for a random while, then the screen would just turn white, but not hang the machine. Adjusting the display properties fixed the problem.
Or maybe you have a failing inverter board (that's what supplies power to the LCD), in which case you are probably hosed. It would be cheaper to buy a new (or different used) laptop than to fix it.
