SpaceWalker
This computer uses a Compaq motherboard....it has the ICS 9250AF-26 PLL chip....I was able to use SoftFSB using the ICS 9250xx-08 setting to boost the clock speed from 700mhz to 781mnhz....Using the v.463 RC5 Client I was getting 1.952mk/s now getting 2.181mk/s....not a bad boost,
***BE CAREFULL*** YOU DO THIS AT YOUR OWN RISK....RESULT WILL VARY....YADA YADA YADA.....
MOOOOOOOOOOOOOOOOOOooooooooooooooooooo..............
