Hello,
I am trying to upgrade my compaq 1800t with a new hard drive (60 gig ibm) and it won't boot from the new hd. I copied the contents of the old hd over using some software I got from another hd upgrade, and tried to reboot but nothing happens. It tries to access the HD and halts with no error at all.
If I boot using winxp cd, it will see the hard drive contents just fine, and will even do a recovery installation without complaint, but when I try to reboot and boot from the hard drive, it just hangs as soon as it tries to access the HD on bootup.
I suspect it's a bios issue since the 1800t apparently has a 30 gig max hd size, but I know there are ways around it. Some hard drive manufacturers used to distribute a drive bios overlay for this exact reason, but I can't seem to find them.
Any ideas? TIA!
Any ideas? TIA!
