Compact Flash Card Reader USB
Banana
3,132
23
Hi guys,
I recently got a hold of a "UFlash" compact flash card reader made by Newer Technology. It was used and didn't come with a driver disk. The manufacturor appears to be out of business--so:
Any idea where I can get the driver files? Or can I use the drivers from another brand?
Thanks for any response.
1YP
LuciferHaze
Banned
Mar 17, 2001
1,162
I'd say give the drivers from another EXACT brand a shot. If that doesn't work than count it as a costly mistake and learn that you never buy anything over the Internet!
Banana
3,132
23
Alright--I'll try those suggestions--Thanks.
Lucifer: Don't tell me you don't buy ANYTHING over the internet? :)
1YP
SaturnX
3,415
Well it seems that this is a mirror of the Newer Technology site, and it seems to have the drivers for it. Anyways, check it out, it may help you. Seems that they have PC UFlash Compact Flash/Smart Media drivers.
--Mark
Newer Technology - Mirror
Banana
3,132
23
Tharyn: You are a godsend! I can't thank you enough--How did you find that site? I downloaded the driver; haven't tried it out yet, but it looks correct.
You're a credit to Anandtech!
1YP
