<< um find a smart media 1gig cartridge, i don't think they even exist. in my opinion compact flash is superior. It has a controller on board so support for larger capacity isn't a problem. smart media is smaller but your limited to what your device can support😛 also the compact flash is slightly larger, allowing for much larger capacities at cheaper prices😛 you can also get ibm microdrives and stuff for compact flash😛 >>
I agree. In real life most of the time they work out to be the same though. However, one thing one must remember is that older machines not built to work with high capacity SmartMedia WON'T work with it, but usually older Compact Flash compatible machines will work with newer cards. It's irrelevant though if you're buying a SM camera today since it should work with all SmartMedia out there today. Because the controller is built-in though for CF, the PC Card adapter for CF is $10. For SmartMedia it's $100. OTOH, you can get floppy adapters for SmartMedia (for $$$) whereas CF is too big for a floppy adapter.
As for speed, expensive compact flash is much faster than cheap CF. However, most of the time the camera is the bottleneck. Furthermore, most cameras have cache memory so unless you take 6 pictures in a row in 10 seconds to exhaust the cache you won't notice the speed difference. I do notice the speed difference when downloading 200 MB of pix through my Firewire CF reader though.
