Be 100% sure you are running as an admin on both machines when you do this or copies will go weird if the ACL on the directory block the files from being written.
Some times this is useful: The /MT can be 2-128 if you have fast storage /MT:32 can make a copy fly since it will copy 32 files at a time. I have seen /MT:128 max out a VNX LUN so take that as you will.
I am logged on as myself (user) with admin rights on machine b. Server is logged onto as the admin. Should I log onto machine b under the admin account or will being logged into the domain with admin rights suffice?
