command prompt help
grcf450
39
I need to open a .ppt(powerpoint) in Microsoft Word using the command prompt. I would really apreciate it if someone could help me out. As of right now its easier for me to just open it by changing Work to open all files but I need to do it using the command prompt.
Thanks!!!
blackangst1
22,902
2,360
Why cant you just double click the program? anyway...
c: \windows\programs\microsoft\powerpoint.exe (or whatever the path is to the .exe file)
grcf450
39
Thanks for the replys guys. Fardringle helped me figure it out. It can be done through the command prompt.
