Comet incoming
skyking
22,889
6,054
so, we get 43 minutes warning this time? We are not getting a shuttle mission put together in time, and Bruce Willis is mos def not up to it either.
Captante
30,354
10,882
Hopefully I'm asleep AND at "ground-zero" .... I never want to wake up. ;)
SKORPI0
18,503
2,430
At the start of 2023 Earth will be visited by a newly discovered comet that may just be bright enough to be spotted with the naked eye.
The comet, named C/2022 E3 (ZTF), is currently passing through the inner solar system. It will make its closest approach to the sun, or perihelion, on Jan. 12, and will then whip past Earth making its closest passage of our planet, its perigee, between Feb. 1 and Feb. 2.
If the comet continues to brighten as it currently is, it could be visible in dark skies with the naked eye. This is difficult to predict for comets, but even if C/2022 E3 (ZTF) does fade it should still be visible with binoculars or a telescope for a number of days around its close approach.
Reactions: Brainonska511
feralkid
17,041
5,103
Nice enough ride.
Charmonium
10,654
3,610
That beast will take out 3 t-poles barely slow down. You'd need to get close c^2 though
OK, the first one would wreck it, but I'm talking scratches and dents Pole #1 wouldn't total it tho
