- Aug 24, 2012
- 1,854
- 12
- 81
Okay, so a friend of mine had to get this router for Comcast's Triple Play service and before I proceed further I want to know if these things are just pieces of sh*t or whether it's just this one in particular.
First of all this thing takes a horrendous amount of time to boot. I've never seen anything this bad, his PC boots faster. It wouldn't pick up a WAN ip so I couldn't even get to the the walled garden to activate it so I ended up calling Comcast to do so. After setting it up, I noticed how slow it was to change settings and navigate the firmware. It was just atrocious, routers weren't this slow 15 years ago.
Anyway, got all his port forward settings and stuff situated and working, but then I ran into a road block. I have one instance in which I need to externally forward a port and couldn't get it to work. Tried, alternate ports, turning off firewall, DMZ, and nothing worked.... After awhile of frustration, I looked into parental controls and noticed that its set to block everything by default. In there you have to enable services and I tried doing that an toggling other various settings and got nowhere and gave up.
At this point I unlplugged it to move it back where it belongs and low and behold, it wouldn't pick up a WAN IP address. So I hooked up the old modem/router and it just worked as expected so I'm pretty much convinced that this thing isn't working properly.
Got home and did a little bit of reading about this and apparently the only way to work around the port forwarding issue is to put it in bridge mode which means that he would need to buy a router because his other device is a modem/router combo. That being said I have to figure out somethings so he knows what his options are.
I just can't imagine a device performing that poorly without being defective, so I advised him to return it for a replacement. However, he needs to use a Triple Play sanctioned device which can only be acquired via comcast to take advantage of the $70/month savings. Without having one, Comcast was charging him the extra money automatically because he wasn't using a Triple Play device and he would have to call for them to remove the charges.
FWIW all Triple Play devices are
So here are my questions.
If DPC3939 really is that bad, does he have any other options available via Comcast that could perform better and/or solve his port forwarding issue.
Is it possible that just renting this device without using it could solve the billing issue? Seems like the simplest solution here.
If the above is not the case, then could plugging it in and hooking it up to coax (so the data center would see the device as connected) be enough to solve the billing issue?
Thanks in advance.
Thanks in advance.
