Comcast Std Componant Cables vs after market Comp. cables?
sswingle
7,183
45
Who needs component cables? Just use a 3 connector stereo pair + composite video cable. Got plenty of those laying around.
crownjules
4,858
That's kind of strange. When Comcast came and setup our cable (HD), we got HD component cables that were black with gold colored metal parts. Anyway, as has been said, unless you are a complete audiophile/videophile (or whatever those are called) you won't notice much of a difference, if any.
Use the money on something which will add noticeable value to your setup - surround sound system / stereo system. Maybe once you have one of those, the extra costly component cables will maybe make a noticeable difference.
Spikesoldier
6,766
can you really do that?
sswingle
7,183
45
Sure. Its just a set of 3 RCA cables, no matter what the label on the package says or how they are color coded.
NuAlphaMan
616
Go with a HDMI cable. I had the component cables and then tried the HDMI and never went back! Far better picture quality.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
They will fit and likely work, but you'll get the best results from 75ohm cables. The yellow video cable should be 75ohm, but the RCA audio cables may not be.
3 yellow video cables = good to go
yellow / red / white = will probably work fine, but maybe not to spec
