Comcast and Bit Torrent
mattford11
337
Well, pretty simple i guess. I'm using comcast internet and bit torrent, and i throttle my upload speed under 3k/s when i download. Problem is that the cable modem disconnects and the lights that turn off are the " cable link " and the " cable activity "
Any one have some suggestionsto keep bit torrent working and playing nicely w/ comcast or cable modem?
Thanks
Matt
mattford11
337
type in experimental bit torrent in google and its the top link ;)
how much is too much for comcast?
AFB
10,718
Try it without using bit torrent and see if that helps. Comcast won't say how much is too much, but I would stay under 15-20 Gig.
mattford11
337
tried it, and it stays online when im not using BT. ive had it up for like 4 hours and it hasnt disconnected yet, but after like 20 mins of use w/ BT on, it will lose connection.
Matt
BigFatCow
3,373
i used to have a problem like this with my DSL, when i got a router the problem went away.
Nothinman
30,672
In 43 days I've downloaded 126G, I havn't heard anything yet.
And for the record I use bittorrent with Comcast and it works fine.
AFB
10,718
Lucky B@st@rd. :) You must not live in an area run by the bandwith Nazis.
JackMDS
29,563
432
Wow, and I thought that the whole Internet is less than 126G. ;)
onelin
874
I've heard typical monthly "max" is 90-100GB before you get a letter. I run BT just fine through comcast, sounds like your modem is funky. I cap to 14KB/sec upload and it still works fine. I easily run 50 on high months, less otherwise.
Dundain
585
I run bittorrent behind a router on my Comcast at home and have never had a problem. However, my apartment has DSL and I'm behind a router and quite often when I get on bittorrent it'll kill the connection for whatever else is running (like IRC, IM, etc.). The only thing I can reason out is that Bittorrent basically just uses almost all the avalible bandwidth, too much information at once? I dunno.
