Color temperature settings gone after I intalled Catalyst 14.9
Carnage1986
92
Today, i downloaded and installed AMD Catalyst 14.9 WHQL. And then, color temperature options on digital flat panel settings tap disappeared.
So, what i can do to bring it back? I can't use f.lux because this software messes colors until re-install Windows.
mhouck
401
I think they moved it to the Desktop color setting under the Desktop Management drop-down. At work so I can't double check, but I'm pretty sure it's still available, just a different spot. Will check when I get home.
f1sherman
2,243
oh i see...
I assumed (wrongly?) that Color Temperature used to be under Desktop Management -> Desktop Color
MTDEW
4,284
37
All I can say is that it's there in my CCC with a clean install of the 14.9's
So all I can maybe add is what/how I did it.
1: I uninstalled the old drivers using control panel / Uninstall / AMD Cat Install manager -
Selected Remove ALL AMD software AND let it uninstall drivers then select to remove Cat Control Panel also. (rebooted) (obviously don't do remove all if youre not running an Intel system)
2: Ran DDU and let it reboot to safe mode and used clean/restart for AMD and remove c\AMD folder checked (Display Driver Uninstaller 13.4.0.0) (rebooted)
3: Once rebooted, checked device manager and be sure it was standard VGA Adapter. ( I always check, it's just a habit)
4: Installed 14.9 driver with custom installation just to be sure raptor/gaming evolved app wasn't installed as usual. (it wasnt even in the list for this driver install)(rebooted)
No issues at all on both my PCs, one with a R9 290 and another with 7950's in x-fire.
Sorry if it doesn't help you, but that is about all I can offer.
MTDEW
4,284
37
Ahhhh....I see.
If I disconnect my DVI cable and use HDMI instead, it disappears.
Are you using HDMI?
MTDEW
4,284
37
I see in the CCC pic in your original post that you have these two options listed under My Digital Flat-Panels.
Scaling Options (Digital Flat Panel)
Pixel Format
I don't have either of those options in DVI, only when I'm using HDMI.
Carnage1986
92
I'm sure that this is DVI. :) I looked some forums and i learned some people suffer this problem. We are waiting for a fix.
mhouck
401
It's under My Digital Flat-Panels ;)
Yep. You are right. I misremembered. Color Temperature Control is definitely available under Digital Flat-Panels.
I did a complete uninstall and ran Display Driver Uninstaller before installing the new CCC. I would suggest giving that a try if you haven't already. Good luck!
MTDEW
4,284
37
LOL, Im sure you do. :thumbsup:
I was just wondering why the AMD drivers are treating your monitor like an HDTV using DVI.
I've gotten used to the AMD drivers treating a monitor hooked up using HDMI as an HDTV over the years. (and its annoying)
But this is the first Ive seen/heard of it happening with a DVI connection.
EDIT: I just checked and It does it if I have two monitors hooked up and one is using HDMI also....(ie: I lose the color temp setting on the monitor using DVI)
Hope they get it fixed 4 U.
