Color Laser Printer?
crazychicken
2,081
It sounds like pretty much they have gotten cheap enough to make up the initial cost difference (over inkjet) in just a couple of years. My main question is: Should I get a B&W laser and keep my inkjet for color stuff? Or get a color laser and keep the inkjet in the closet for only when I need really good photos printed?
Any opinions are welcome!
Thanks,
Dave
crazychicken
2,081
Yea, the plan was to print pictures on the inkjet. But should I print black and white documents on a color laser or a black and white laser?
Dave
paperfist
6,539
287
www.the-teh.com
Dave
Per your first post I think leaving an inkjet in the closet would be unwise as you'll end up drying the ink out in the cartridges.
I'm ordering a all-in-one color laser soon so I don't know for sure but it seems wasteful to use a color laser to print b&w unless you'll use it for color documents instead of color pictures. I can say I'm extremely happy with my soon to be gone b&w laser printer as I hardly every need to replace the cartridge and the printing is superior to inkjet.
Lemon law
20,984
The flaw with this plan is to assume you can just put an inkjet on a shelf without it clogging, and then if you use the printhead on the cartridge type inkjet, you are often faced with replacing all your cartridges.
The flaw with most prosumer color lasers is you have basically four color drums printing in sequence, a complex mechanism required, and then when the toners run out, most people buy OEM replacements, and the sum of those four replacement toners exceed the original cost of the printer. And as was pointed out, color Lasers simply do not do photo printing.
IMHO, the only way to beat the consumable costs game is to refill your own inkjet cartridges and print often enough. Quite easy and supercheap with the older non chipped canons using the BCI-3&6 cartridges, and now almost as easy with the latest generation Canons now that the chip is cracked. And chip resetters are now available for $30.00 or so. But better hurry, because Canon, now that their chips are cracked is going to bring out a new and harder to crack generation of chipped printers.
And in my case, because I seldom print, I bought a used brother all in one monochrome Laser, but if I need color, I use my wife's Canon ip 4000 inkjet. And if my wife needs a lot of copies quick in monochrome, she can use my laser for the speed, but we can both print to the inkjet for far less consumable costs per page. In fact she can do plain paper color for less than my monochrome toner costs per page. And my wife normally prints enough to keep her inkjet printhead clog free anyway and using dye based ink for black text helps seal the deal.
TheKub
1,756
I'd buy a decent reliable B&W laser and then spend the 9 cents a print at a photo place if I need photos printed.
But thats just me.
biostud
19,960
7,050
I'm looking at the canon 5050n i-sensys color laser printer, I think it will be a good buy, but not many reviews are available yet.
boomhower
7,228
19
But thats just me.
+1 same method I use, but I wish it was 9 cents around here. Considering most with color inkjets by the time you factor in ink and decent photo paper it is still cheaper to just go to a local photo join, drug store, or walmart to print them out.
