Can anyone tell me what size of fuse to use for input 120 vac 60hz 46w. Output is 20.5v 1.4a 28.5va. It is for a Coleman battery charger pmd8146 model pa1801
I think you've misunderstood the kind of power supplies that are discussed on this forum - this is a computer/PC hardware forum, and the power supplies discussed here are PC power supplies. I'd suggest looking for a DIY forum or something similar. Good luck!
