- Jan 21, 2005
- 17,722
- 6
- 81
I'm looking for some help using ColdFusion. I am working on a form where a user can input a month and year through a drop-down box. I then want that to be passed into a query (<cfquery>) that will then be presented on the page.
I am very new to ColdFusion and our company uses it almost exclusively. The form method is POST. Here is what I have so far.
Then, this is what I have inside of a <cfquery> tag:
But, I'm not real sure how to put that into the query. You'll see a.AssignedDate in there, but I just don't know what the syntax is. I've tried looking online to no avail.
Thanks!
Code:
<!---MONTH--->
<select name="beginYear" size="1">
<option value=""></option>
<option value="2000">2000</option>
<option value="2001">2001</option>
<option value="2002">2002</option>
<option value="2003">2003</option>
<option value="2004">2004</option>
<option value="2005">2005</option>
<option value="2006">2006</option>
<option value="2007">2007</option>
<option value="2008">2008</option>
<option value="2009">2009</option>
<option value="2010">2010</option>
</select>
to
<!---MONTH--->
<select name="endMonth" size="1">
<cfif #form.endMonth# EQ ''><option selected="selected" value=""></option></cfif>
<cfif #form.endMonth# EQ '1'><option selected="selected" value="1">1</option></cfif>
<cfif #form.endMonth# EQ '2'><option selected="selected" value="2">2</option></cfif>
<cfif #form.endMonth# EQ '3'><option selected="selected" value="3">3</option></cfif>
<cfif #form.endMonth# EQ '4'><option selected="selected" value="4">4</option></cfif>
<cfif #form.endMonth# EQ '5'><option selected="selected" value="5">5</option></cfif>
<cfif #form.endMonth# EQ '6'><option selected="selected" value="6">6</option></cfif>
<cfif #form.endMonth# EQ '7'><option selected="selected" value="7">7</option></cfif>
<cfif #form.endMonth# EQ '8'><option selected="selected" value="8">8</option></cfif>
<cfif #form.endMonth# EQ '9'><option selected="selected" value="9">9</option></cfif>
<cfif #form.endMonth# EQ '10'><option selected="selected" value="10">10</option></cfif>
<cfif #form.endMonth# EQ '11'><option selected="selected" value="11">11</option></cfif>
<cfif #form.endMonth# EQ '12'><option selected="selected" value="12">12</option></cfif>
</select>
<!---MONTH--->
<select name="endYear" size="1">
</select>
</td>
</td>
Code:
<cfif isDefined("form.beginMonth") AND isDefined("form.endMonth") AND isDefined("form.beginYear") AND isDefinied("form.endYear")>
a.AssignedDate >=
</cfif>
Thanks!
