Originally posted by: jadinolf
Linky no worky but if you want one I saw a pile of them on my last visit to Costco.
the link works fine with a little adjustment. how can any atoters be this helpless
Originally posted by: Shaftatplanetquake
I've seen it in action. Coworker bought one. It does a terrible job of melting solder. Even adding lots and lots of flux does not help the iron heat up enough to melt the solder. It works better with very thin solder, but even when you use the very thin stuff it has a lot of trouble actually melting the solder. Maybe if the ingredients in the solder are totally premium, like $50 solder it works well. But with 2 different types of solder, two different thicknesses, I had one HELL of a time even getting the stuff to melt.
$8 radio shack soldering iron works great.
Problem is even if the solder is heated, if the pins or wires you're soldering aren't hot enough the solder joint is worthless.
Originally posted by: rudeguy
they suck hardcore. 2 of my installers got them and returned them the next day. If you don't need a portable one, just get a decent one from Radio Shack.
Originally posted by: Engineer
I've heard/read that they are junk.
However, there is a "real heat" cordless soldering tool (McMaster Carr carries them) for about 50 bucks. Hold in button and heats up in 5 seconds and has flashlight toward tip to help see wires. States it will solder 400 uses per charge. Charges in 4 hours.
We use one at work.
We use one at work.
We use one at work.
I also read/heard they were junk. However I spend the $20 on it and it works just fine. I'm sure there are some soldering it might not work well for due to it's design but for normal wire soldering(wire to wire and wire to post) it seems to work well for me atleast.
I've also seen the McMasterCarr tool. If I was rich like Engineer I'd buy that one but I'll stick with the coldheat one in my travel bag for now.
CsG
We use one at work.
CsG
P.S. Cad....switch to that Automation Direct stuff and you'll be able to afford a good soldering iron. A nice temperature controlled Weller hits the spot! 😉
