Ok, so I have been having a cold boot issue that when my PC is off for a while, it takes a reset or two to get it to post. Once it comes up though, it is fine. Now, this becomes increasingly noticable, and more resets are required as the ambient temperature in my room decreases. Yesterday it was pretty damn cold in my room, and it wouldn't post at all, just constantly giving the memory error beep code. I have run memtest on the memory and it is fine for 8+ hours, so that is not the problem. CPU is not OC'd either.
So, seeing as temperature effects the bootability so much, I think "Lets introduce some heat to the environment and see if that helps." I get a hair dryer and aim it in the side intake panel while turning it on. 1 reset later, it boots up fine!!!
Needless to say this is frusterating beyond belief, and I have never heard of temperature impacting a component so much, and I don't even know what component is at fault. The memory seems fine, could be CPU memory controller (but I doubt it), motherboard is possible, PSU could be at fault but all rails were verified, so I am truely at a loss. Stats are shown in my sig. Any thoughts/suggestions/advice would be appreciated.
What sucks is I don't have another mobo/cpu/psu that I would be able to swap out and test each component, so I may have to take it to a local shop for diagnosis, which I'd like to avoid due to cost.
