so the heat in my ride comes out hot when im driving. but when i come to a stoplight or if the car is running idle, it blows cold air. whats up with that? something need to get fixed?
SandEagle, are you sure you have air conditioner installed in your car? From your description it seems that you haven't. Without air conditioner, you will get hot air only when your car is running, couse it's heat from car's engine.
It may be the above issues, or it may be a partially or largely plugged heater core that is only getting enough hot water flow when the RPM's are up and the water pump is putting out pressure.
