Yes.
Altitude also reduces a cars power output.
Humidity also has an effect.
i would say that a denser air charge makes more power.
Cooler temps, low humidity and dew points.
Like was said before however, cold tires are not the best for traction.
Once the engine is warmed up I'd think the air could be as cold as you can get and still not be too cold.You don't want too cold as the air becomes denser, oil is thicker at start etc...usually somewhere in the 65-75F would probably be ideal in terms of testing for 0-60 or whatnot.
Can't compensate for oxygen content. It's like getting a free displacement boost.Depends on a ton of factors. I believe generally if you had all things equal, colder air tends to offer more power but warmer tends to offer a bit better fuel efficiency. With modern ECUs though, I don't know that you'd see much of a difference just because they're going to try to keep the engine in optimal ranges and so it will try to compensate for temp differences.
Hot air rises thus making your car lighter and if there's one thing Colin Chapman has taught us...it's that lighter is better.
I hate you so muchSure you can, that's why you strap on some forced induction. :awe:
