Coffee questions
NiceCold
543
I used to be a wannabe hardcore coffee drinker that i go to joe, fresh n easy, henry market, wholefood just to try out all their fresh coffee. so far i like italian roast in wholefood. wholefood is best place to get fresh coffee beans. you scoop it yourself and they even have grinder there at the spot. oh forgot to mention they roast the beans at the spot too right in front of yo face! very fresh and everytime you visit, the beans is always warm! from fresh roast!
tried ethopia coffee and it is so terribly sour! the bean color was light and off-color, i thought it is different from the others so i tried it. so sour. end up throw out the window.
italian roast plus kuldensen gold star cream is the best!
Griffinhart
1,130
One day this will grace my kitchen counter:
Ooooh, what is that?
NutBucket
27,181
649
What if I said beer is an alcohol delivery mechanism and that if you need more than Budweiser you need to turn in your man card?
quikah
4,228
770
My former boss used to roast his own beans. That was nice, get some wicked good coffee once or twice a week when he brought it in. He used a hot air popcorn popper to roast. I thought it was kind of funny, but it works.
lxskllr
60,945
11,270
I think that's the "official" way to do it on the cheap. You can find them at thrift shops, and yard sales. Anyone interested in roasting their own beans should keep that in mind.
KillerCharlie
3,691
68
I've heard lots of good reviews about the aeropress. Its advantage over a french press is the filtering system. French press requires a consistently coarse grind, otherwise little bits will get through the metal plunger filter. The aeropress gets away from this by applying higher pressure through a paper filter, so you don't need nearly as good of a grind consistency.
I bought a decent french press at target and use a crappy grinder. If I plunge it nice and slowly I barely get any pieces of beans - only extremely small sediment goes through which I actually like to some extent. I'd prefer to use a nice grinder and have a bit less grit, but not enough to pay a ton of money for a conical burr grinder. Even a good grinder will still have a bit of stuff getting through a french press, which the aeropress avoids.
Pliablemoose
25,195
OMG, just fired up the KitchenAid grinder for the first time, and pulled my first shot, it's nearly perfect.
lxskllr
60,945
11,270
My daughter has a Mr Coffee electric version of that, and my first espresso maker was a stovetop version minus the frothing wand. Everyone craps on that style, but I like it ok. They might not make the best espresso, but you can't beat the price. It's close enough, and I usually prefer mass quantities of coffee. I use the steamers to make a treat cup every so often.
WelshBloke
33,612
11,749
They definitely don't make the best espresso, but I still prefer it to non pressurised methods.
They are good for taking camping as well. :cool:
ponyo
19,688
2,811
No Atot love for this sort of thing?
I have no idea how to use a machine like that.:confused:
I use this exact machine. One button operation. :awe: I just made a cup while reading this thread. I also checked how many cups of coffee and espresso I've made since purchase couple years back. The machine displayed 1,858 cups. It's safe to say I got my money worth out of this machine. And it's still going strong.
Gothgar
13,429
I have a French Press... but I usually cant be bothered with spending the time for it, rofl
I have a Bunn drip, and a burr grinder, makes great coffee. Without as much work.
Cerb
17,484
33
86
+1 to a french press. They're fairly cheap, easy to use, hard to screw up with, there are no consumables, and they are generally easy to keep clean. If you use a blade grinder, you will get plenty of sediment, though. With a burr grinder, the amount of sediment will be fairly small, just a few times more than you'd get with espresso.
Note that Bodum has started slacking on quality, in the face of cheaper competition. A bought a new one a few years ago to have one at work, and it did not impress. If you check out reviews, notice how so many of the bad ones are having issues well after purchase.
My more recent one is hard to clean the silt from the plastic grate, the plastic top section does not fit straight on the beaker (IoW, coffee cools down quicker until it is no longer steaming), and the band holding on the handle is already rusting. My nearly 15-year-old Bodum press, meanwhile, has no corrosion, perfect-fitting parts, and the plastic is all easy to clean (hot soapy water soak for 5-10 min, worst-case, will get it odor-free). That the nut was plastic, and eventually stripped, is the only con I can think of to it (I now use my old press, with the nut from the new press :)).
Classic bean-counters-riding-a-brand-into-the-ground story, I'm sure. Today, I would either get a cheaper one, or a more costly brand that prides themselves on quality.
Lately, I've been really considering buying a coffee roaster. My Cousin has friends that run a green coffee reseller business and NOTHING tastes better than a cup of coffee brewed from freshly roasted beans. My lazyness has been the only thing stopping me. Home roasters tend to only handle small batches, and It does add a significant amount of time and effort to get that first cup of coffee.
An air popcorn popper with vents on the sides of the cylinder, rather than the screen on the bottom, is cheap, and fairly easy. A metal colander with large circle openings (as opposed to thin slits) can get rid of most of the leftover chaff, and helps cool the coffee down. You won't get the consistency of a machine made for coffee roasting, but you will get good coffee, with a bit of practice.
I've not needed to bother with one-way-valve bags or any of that, just a jar with a tight-fitting lid, after it is a couple days old. I figure if it isn't used up in a week and half, I've made too much.
On espresso machines, the key reason to avoid the cheap ones is cleaning. I had one, and it actually could make a decent cup...for about the first 3 months. If you can't take it apart in a matter of minutes, to clean every single surface, consider it garbage (good espresso machines will also have materials safer for running acid/base cleaners through them, where most dept store ones have a fair bit of bare aluminum).
Doppel
13,306
I don't know why but I really and I mean this want to try that cat sh*t coffee.
