- Aug 25, 2001
- 56,572
- 10,208
- 126
Pulled out a brand-new Adata 16GB USB3.0 UV128 Yellow flash drive, opened the package, plugged it into my DeskMini's front USB3.0 port. Heard one chime from Windows, but not two. Doesn't show up in Explorer.exe or Disk Management console. Device Manager shows a USB Mass Storage Device, with a "Code 10 - Cannot Start - missing Device" error. Something about USBSTOR. On that same machine, an Emtec Click USB2.0 drive in the same port is recognized correctly, no problem.
So I fired up another machine, this one a Haswell H81 board, with front USB2.0 connected, and plugged it into the USB2.0 ports. Same deal. One chime, not two, and Code 10 in Device Manager.
I've tried with two brand-new Adata drives. Same deal.
So, it's not the hardware, it might be an incompatibility with the OS, something with a recent Win10 update, maybe? Either that, or I just got an entire bad batch of flash drives. These drives worked wonderfully for me in the past, I don't understand how the new batch could all be bad.
Any ideas?
The drives ARE recognized in the BIOS, on the DeskMini. Just not in Windows.
https://answers.microsoft.com/en-us...10-error/7152cb63-9258-e011-8dfc-68b599b31bf5
https://support.microsoft.com/en-us...rt-code-10-error-in-device-manager-in-windows
https://support.microsoft.com/en-us/help/2970908/how-to-use-microsoft-easy-fix-solutions
https://www.newegg.com/Product/Prod...1761&cm_re=Adata_UV128-_-20-211-761-_-Product
Hmm, several recent reviews, of multiple OOTB DOAs. Not a good sign. One fellow mentioned firmware errors, that he was able to fix with some sort of firmware tool from Adata.
I got to a USB flash drive online recovery page:
http://www.adata.com/en/ss/usbdiy/
Only, you have to enter the serial number, and the field that they give you to enter it, won't fit all the digits! WTF ADATA!?
I'm no longer going to recommend these drives, they have turned to GARBAGE. Two DOAs, in a row? Bad firmware? Bad tech-support page to back them up? Adata, clean up your ACT!
Now, I feel bad, that I ordered a pair of Adata SX8000 M.2 SSDs. If this is how they treat their flash drive customers, do they treat their SSD customers any better?
I noticed that they no longer offer Acronis downloads on their web site anymore, they only offer the free version of Macrium Reflect.
Edit: It gets MORE INTERESTING.
All three of the "bad" drives (plugged into multiple PCs, all running Win10 64-bit), WORKED FINE, plugged into a DeskMini, running Win7 64-bit SP1, with the Servicing Stack update (April 2016), July 2016 rollup, and the Cumulative Update Rollup v4.
So, looks like a defective driver in Win10 RS1? Affects some USB3.0 drives, but not USB2.0 drives?
Those people that say that Win10 "doesn't have bugs"... are lying.
Any ideas?
Cons: FIRMWARE ON THESE IS COMPLETE GARBAGE. We bought 3, 2 had DOA firmware right out of the box. After using the ADATA update utility they came back to life for about 2 uses [300MB of writes] then died again. The one that wasnt DOA was so painfully slow that its embarrasing that its labeled as a USB3.0 device. USB 1.1 is closer to actual performance.
Other Thoughts: These drives serve more purpose being in a trash bin than holding any data of any kind as it will eventually corrupt itself.
