Coaxial output on DVD player..?
Lithium381
12,452
I've got a dvd player with an oarnge coaxial output.....and a receiver with an oarnge coaxial input.......what type of cable goes there? it seems to fit a standard rca, but that would almost seem to easy...what am i missing?
LordJezo
Banned
May 16, 2001
8,140
Is it a digital audio coaxial out?
If so just go to Radio Shack and get one. It's how I have mine hooked up and the surround sound is great.
Only thing better is the optical out, but my reciever dosen't have an input for that.
Lithium381
12,452
yeah it's digital....my receiver has optical in, but my player doesn't have optical out, but coaxial should work fine, how much are they?
Maverick
5,900
Its a coaxial cable...yes you can use regular RCA as the connection since it fits, but its no guaranteed to work. I used one for a while and it did work most of the time, but sometimes the dvd player would fail to recognize the connection. Turning it off and on made it work. The digital coax cable can be had for cheap at radio shack. No need to get with Monster Cable for it.
Some people think coax is better than optical but its a toss up...99% of people can't tell the difference.
Jan 9, 2002
5,232
Exactly what I was going to post. I use a Monster Cable coaxial from my Hollywood+ DVD decoder card to my TV, but it's only because I got it for 3 bucks with an employee discount when I worked for Best Buy last year. One from Radio Shack will be just fine! The only reason I prefer optical is because of the technology behind it and the bragging rights. :D I can't tell a difference either.
Lithium381
12,452
would i be able to tell a differnece between the 5.1 analog out and coaxial? i mean just how much of a difference is there?
Gunbuster
23
The only reason to use analog 5.1 out on a DVD player is if your receiver has no DAC of it's own
Lithium381
12,452
hrmn, well it DOES have DAC, so i geuss i have no excuse not to do myself the favor and go down to rat-shak and grab a cable then....
amnesiac
15,781
Also you won't be able to use DTS / DD on your receiver (if it supports it) unless you have a digital cable as well.
