Coax Cable
munruss
I need to run 100' of television coax cable. It's going from a splitter from the basement to the 2nd floor. Do you know of any decent online stores that sell this?
Best Buy has Monster Coax...Don't worry that it costs a 'little' more...It will make your channel surfing faster since the cable signal will travel faster to your TV if you use it...
somebody's sarcasm meter is busted (I hope 😛 )
Nate
Nate
Maybe munruss's doesn't work though = I'm sad.
I'd check your local Home Improvemtne store first. Can get bulk stuff like that pretty cheap. Otherwise find an online cable place like trianglecables.com, cablesforless.com, etc. There's tons of places that will sell that.
sure, but it is somewhat of a ah heck to route with the ends on. You have to drill bigger holes, it snags, you have to protect the wire.
