I just built my first pc and on bootup I'm getting this message:
CMOS settings wrong
CMOS date/time not set
Chassis intruded
Fatal error...system halted
I tried to clear the CMOS, however I don't know if I did it right. I cleared the RTC RAM (CLRTC) because manual says the jumper allows me to clear the RTC RAM in CMOS. I moved jumper cap pins from 1-2 (default) to pins 2-3 and kept it that way for 10 seconds...then moved it back to pins 1-2. On bootup I'm holding down the delete key to enter BIOS, but it doesn't get that far as I'm getting the same errors as above.
Any suggest on what this may mean. Also I'm getting three beeps on bootup. I checked my memory and it seems to be seated properly.
Any suggestions?
CMOS settings wrong
Chassis intruded
Any suggestions?
