i just recieved my new board/1.4athlon/fan TODAY/now... installed it, had the SAME EXACT problem.. went on the anandtech forums to find out what the deal was with that.. anyway, i recieved the whole 'cmos battery low' error and some other error at once.. tried rebooting a couple times nothing worked, even resetted the bios.. but i remember...
the first thing i did was reset the cmos, that didn't work..
the second thing i did was 'load optimal values' in the bios --> save changes and quit. turned off computer for about half a minute.. turned it back on and THAT WAS IT. NO MORE errors.
the third thing i did do was 'load best performance values' or something like that and i didnt get anymore errors as well..
i did read somewhere on this that it had to do with ram timing settings setting one of the timings to 7 but that didnt work for me, only thing that did work for me what was mentioned above..
if you want more info do a search on the forums for the actual motherboard model you are on.. theres tons of info/threads on this cmos error topic..
good luck... if you have any questions.. i'll be glad to help, you can pm me anytime.
