Hi. Yesterday, I built my first computer. And since then, I have had so many problems. Here are the specs.
Athlon 64 3000+ s.939
MSI K8T Neo2
2*516 mb corsair value ram
XFX Geforce 6600gt 128mb (vga)
Samsung SP1614N 160 gb 7200rpm ideo hard drive
liteon dvd writer
some sound card
some video capture card
Anyway, I put it all together (which i know i shouldn't have, i should have just put the main parts in, not even the hard drive), and plugged it in. Well since then it has been working ok except everytime i boot up i get a error like "cmos wrong" or "cmos/GPNV Checksum bad". I tried resetting the CMOS by using the cmos reset jumper pin, but it goes back to CMOS wrong the next time i boot it up, and then to cmos/GPNV Checksum bad". I don't know what to to about this, I have heard mixed ideas about this.
Also, even though this error was occuring, I procedded to install Windows XP SP1. It installed fine, and then when I got that installed, I installed the drivers that came with my mobo (Via chipset driver and some other stuff). I installed that, it made me reboot the computer, and then when it booted up i installed my video card driver. Well, after that installation it made my computer reboot, and since then it has not been making it past the windows xp title screen (with the bar on it). It doesn't make it to the loging screen, the video just shuts off, but the computer stays on. I have rechecked the cables and stuff but I don;t think that that is the problem.
Also, when my computer WAS booting up, in windows xp i noticed some wierd things. For example, when I was in a situation where I could scroll down or upon the screen (ex. a long text document), the scrolling lagged (like the system was under a lot of strain). However, the computer was quick in other concerns.
I know this has been a long letter, so thankyou very much for reading this and helping me. This is my first build. Thanks a ton!
Matt
MSI K8T Neo2
liteon dvd writer
some sound card
Matt
