Originally posted by: scrawnypaleguy
I bought the CM Stacker 810 last week. I had it for two days, then returned it. The reason was not that it was loud, or that it didn't cool effectively. In fact, it's extremely quiet and cools better than anything I've ever had. The problem that I had with it is that the PCI slots are out of whack! As basic and as stupid as it sounds, Cooler Master royally screwed up on this part. For some odd reason, they're actually halfway outside the case. I plugged in my pci cards, and was amazed. First off, they're extremely difficult to get in and out due to how the pci slot cover inserts into the case (it's kinda hard to explain), but more importantly the screw holes are too far outside the case. With my motherboard screwed in nice and tight and straight, the pci cards couldn't be screwed in, as the hole was far enough away as to make the little bent part of the pci card block it. I would show some pics to better illustrate what I'm saying here, but the case is already on its way back to newegg. In short, don't buy the case. I went to performance-pcs.com and got their Lian Li PC-7B, which is actually better than the V1000 which I also considered, the reason being that for a little extra, they'll drill a 120mm blowhole in the top of the case, allowing for three 120mm fans. It's cheaper, and with the mod, cools better. But even if you don't like that one, stick with Lian Li, they've never disappointed me in the past.
