- Aug 26, 2014
- 1,792
- 508
- 136
So, my question is pretty simple: does anyone know if this combination will work? I'm specifically thinking of RAM clearance. I've been reading around, but can't find anything specific - which unfortunately is pushing me towards thinking it can't be done. I've made a mockup/sketch/thingy with the relevant measurements (as well as I'm able to discern them, at least), here: https://www.dropbox.com/s/zs2udev25f1rkzp/ASrock+212-evo.jpg?dl=0
The lines are at the inside edge of the RAM slot (i.e. the RAM PCB thickness, without the memory chips and heatsink) and on the outside edge of the RAM slot, and the distances are from the heatsink base to the closest point directly above. It looks to me like this would be a very tight squeeze. Am I right? I've never had to consider RAM clearances before, so this is a new problem for me. Of course I'll be using low profile RAM.
I'm already aware that the backplate will conflict with several chips on the back of the motherboard, but that can be worked around (don't really need the backplate for horizontal mounting, after all).
Rotating the heatsink is unfortunately not an option, as this orientation is ideal for airflow in my Fractal Node 304.
If this won't work, do you have any other heatsinks to recommend? This is for a quiet, 24/7 active living room media hub/file server.
